Reset a TOF ?
Garyuk
Jun 2004
Novice question about ending a TOF on an Allen Bradley SLC early. By that I mean I have an off delay timer counting up and I want to use an input to force it to timeout and change state before reaching the preset value. Is this possible and what is the preferred method of achieving this?
Thanks.
Simply move the preset to the accumulator when the time-out input is high:
Kind regards,
There is this warning for using RES with a TOF:
"Warning! Do not use the RES instruction to reset a TOF instruction. A RES always clears the status bits and the accumulated value. This could result in unpredictable machine operation or injury to personnel."
A bit cryptic as to what the problem really is.
I would experiment with it to find the truth.
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
71
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
352
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
91
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
101
