Reset Timer In Micro810 CCW
gbradley
Apr 2002
Corona, Ca.
1,638
I am trying to create a timing circuit to compute Instantaneous Pcs/minute.
I usually take 6000 and divide it by the elapsed time between pulses to get Pcs/Minute
I then Reset the Timer for the next pass.
So I am trying to do this with a Micro810, and I can’t figure out how to Reset the Timer.
In RSLogix it is the Reset Bit.
Any suggestions?
According to CCW help file. The falling edge of the input stops and resets the timer.
Oh.
I don't know how to do that.
I was hoping to start a Timer when the flywheel passed a prox switch, and then the next time it passed it, log the time, and then reset the timer at the same time.
If I could somehow reset the time, I'd be in business.
Just one-shot the prox and use that one-shot to drop the input to the timer AND move the timer accumulated to some location for evaluation.
There's going to be a lot of possible variations on this theme.
what about in structured Text
what about in structured Text and in ST how to reset TON timer ?? the sofware dosen't able to do DELAY.IN:=FALSE or DELAY(FALSE,T#5s)
give this error.
Error 2 LL_DELAY.IN:Illegal access to function block instance parameter
I don't think the OP has been waiting the last five years for a solution.
I'll say...
I should have replied back in the day when I figured it out. (or someone else figured it out for me :site:)
I think I used a Pulsed input.
Anyhow, I think that project has been happily running for about 5 years now.
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
134
Hi there I'm guessing this is a straightforward one but after much experimenting I've been unable to find an answer. The software is TIA V16...
2,397
Processor: 1769-L30ER; Logix 5000: v32.02 I have an AOI that's been used in previous applications without issue, and have added a TON...
2,831
Hello Folks, I am new to Direct Soft, but a customer has a program that need me to edit. It is a DL06. We have a TMR function (T4) that we want...
24
5,834
I would like to use a numeric entry from a C-more HMI to change the preset in a timer in Do-More. How might I go about that? Thanks
1,307
