resolver mechanical phasing
James Ross
Jun 2019
Australia
30
Hi.
I have a 1326AB servo motor and its resolver is out of tune.
How is the procedure of mechanical manual phasing in Allen Bradley?
Is that V+ W- and sine wave null? Or what?
Regards.
welcome to the forum.
please explain what you mean by out of tune?
does the servo home when you tell it to?
when you tell the servo to go forward, does it go forward?
does it go in reverse when you tell it to?
in my opinion,
if it homes, goes forward, and goes reverse when you tell it to, the servo is working, you have mechanical issues. that's been my experience.
james
Thanks for replying James
No, I mean it does not go any direction.
This mechanical adjustment of phase alignment I read about it in some forums.
I think it is different from brand to brand or from encoder to encoder, or even one kind of resolver to other kind, did you heard about it?
Regards
James
To the best of my knowledge AB has never published this information. At least I have never seen it floating around out there.
What drive are you using the motor with?
Keith
Keith
It is a kinetix drive.
Does it make any difference? And how?
Isn't a right documentation of the motor (you say before replacing the unhealthy resolver) enough for gaining of this kind of information?
Regard
James
An instance
For your information here is what Kollmorgen manual on "AKM® Servo Motor Selection Guide" (page 54) states:
"Resolver Alignment
With positive DC current into phase W and out of phase V (U floats)
the resolver is aligned to electrical ±5 counts. ie. Voltage S1-S3
set to null voltage S2-S4 max in phase with reference (R1-R2)."
Regards
James
It can. Some drives are designed to automatically determine the feedback device offset, much like what Peter Nachtwey indicated. If the drive had that capability you wouldn't need to specifically phase the resolver. The drive would calculate the offset and move on with live. Resolver phasing was only really a physical requirement with analog drives. Once you have a digital drive requiring mechanical resolver phasing is just laziness. Depending on the Kinetix drive (300 / 350 / 6500 / 5700) there may be a function in the commissioning section that will calculate an offset for you.
I'm not sure what you are saying here. I can take it two ways. If you are saying that you could have powered the motor yourself and measured the resolver feedback independent of the drive, yes you could. That would be a way to do it. If you are saying that the motor manual should contain the information on resolver mechanical phasing, that is only true if the motor manufacturer doesn't want to profit from your pain. Rockwell is basically requiring you to return the motor if the resolver fails. They generally run pretty closed. To be fair, there are ways to incorrectly mechanically phase a resolver that will cause the motor to take off at ludicrous speed. So it may also have an element of CYA.
Keith
Yes I mean I powering the motor by myself and measuring the resolver feedback independent of the drive. In my case, I have't access to drive for factorial reasons. what I said was that if you force to replace the feedback for some reason (not only defectivness). You have to document it by one of the six combination of U, V, W phases and positive/negative DC current. Wouldn't be helpful?
Regards
James
You are correct, especially in the case of AB motors where there is no mechanical phasing information available. You would have to take a known good motor, apply a voltage to some phase combination and measure the resolver feedback. In the case of doing it on your own, you could experiment with phase combinations until you get the one that provides the easiest to repeat resolver signal. But that really doesn't help you now.
Keith
Dear Kaite
The benefit of these forums is to share the experiences.
Maybe someone has this experience, or even someone find a document regard to AB motors and put it here.
Regards
James
Hello, We have been floating around the idea of making a test bench / training station in our facility. Our two biggest "customers" for servo...
1,096
Is there an easy way to put back a resolver that was accidentally removed from a servo motor? Thanks for your feedback
1,524
Hi, I have some Baldor (Baldor is now ABB) servo motors that have revolvers for position output. But to my surprise the Baldor MicroFlex...
3,793
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
Hi All I need to test/program a GEM80 FIFAC 9274 resolver/synchro encoder card. Does anybody have any information about this card or know how to...
1,073
