Retentive timers
jjnelson81
Apr 2007
Springfield, MO
32
I am posting to pick your brains. I am trying to create an automated maintenace notification system for equipment. The one obstacle I think I am going to run into is loading from the EEPROM upon corrupt memory. All registers would lose their values (i.e. machine run hours which would be used to control the maintenance notification).
Is there some advanced features that can be utilized to store information (register values) to non volitle memory of some kind and then reload the values after a corrupt memory EEPROM load?
Specifically in CLX processors.
Thanks in advance
Upon corrupt memory is a setting that is selected during the EEPROM Loading process.
You have 3 options, upon corrupt memory, on power-up and user initiated.
Upon corrupt memory is most commonly used, i.e. processor losses power for a long period of time and the backup battery fails. The memory is then erased and this would constitute to load from the EEPROM.
It doesn't help with the memory problem, but for your application look at using the TOT instruction instead of RTO.
Fix the tagname.In value at 1.0 instead of connecting it to another tag. Fix the gain at 1.0 and set tagname.timebase to 2. This configures the TOT to totalize time in units of hours. Setting tagname.timebase to 3 configures it to totalize days.
Use the tagname.EN bit to start/stop time totalizing.
Your TOT tag contains some elements named .Target and .TargetDev1 and .TargetDev2. Set Target to the time where you want to signal needed maintenance. .TargetDev1 and TargetDev2 can be set to give you advance warning that the maintenace time is approaching.
.TargetFlag, .TargetDev1Flag, and .TargetDev2Flag are booleans that turn on when the TOT reaches the specified value.
Once maintenance has been performed then instead of resetting, simply add the required time until the next maintenance is required to the .Target. This way you also have a total of how many hours or days the equipment has accumulated over its life.
Hi all, I have what is likely not a complex issue, but I am working in Automation Studio and want an accumulating/retentive timer when a...
17
1,972
Anyone please Whats the different between the retentive and non-retentive timers
11,602
Does anybody know the maximum number of retentive timers I can use in a Mitsubishi FX series? As far as I can tell it's 10(T246-T255). Problem is...
5,833
Ok here is my problem. Below is a picture of the ladder i am using to control two timers. T13 is simply a looping timer that counts down from 60...
19
10,269
