Retort Control?
sirhiss2
Oct 2003
109
What is Retort Control?
What does it have to do with Boilers?
Where can I find a typical process explained?
Electrical Eng. Technologist
A retort , or a muffle can be a type of furnace , or in the case of some of the equipment that I have experience of , a crematory .
A resort on the other hand is a nice place to go on holiday .
In the US Retort is a type of system used in food or pharmaceutical. I know that in many cases its used for sterilization of containers (bottles, cans etc) that product is placed into.
A definition of retort: A closed laboratory vessel with an outlet tube, used for distillation, sublimation, or decomposition by heat.
This site is about Retorts:
http://www.retorts.com/
A boiler retort is the heated pressure vessel in which steam pressure is produced.
A distillation retort is the vessel that holds the material from which the desired product is distilled, even if that retort happens to be steam heated from a boiler.
My experience is with vacuum furnaces, both debinding and reduction. The vacuum furnace retort is an optically tight but not air tight chamber within the main vacuum chamber and within the bounds of the heating elements. The retort contains the material being processed. As the material is processed the retort helps assure that out-gassed compounds find their way into the evacuation manifold and are removed through the vacuum pump, instead of wandering over to the chamber walls to condense.
As you can see, the definitions of "retort" vary widely, but the one common thing is that it is the chamber that holds the material being processed.
A retort is a hot box , how you heat it and what you put in it are up to you .
Hi, Is Control Expert V15.0 supposed to support multiple monitors? I'm running Control Expert V15.0 on my host Windows 11 PC, connected to two...
35
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
55
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
79
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
132
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
108
