RFID & RsLogix 5000 (56-TR-8090A)
Trox
Dec 2016
United Kingdom
Dear All
I am currently intending to use the RFID reader/writer (56-TR-8090A) using RsLogix 5000. I have powered up the communication block (56RF-IN-IPS12) AND/OR (56RF-IN-IPD22) and the transmitter seems to be switched on.
When i search for the device in the "Discover Module" Option i am able to add the Communication Block 56RF-IN-IPS12 OR 56RF-IN-IPD22
For example i have created a new 56RF-IN-IPS12 named "RFID"
The intended commands that i should get from this variable would be like RFID:O.Run etc
but instead it doesnt give me any commands...
I cannot even find basic commands except just arrays of Data[0] to Data[180]
I need help on this topic asap
Any help would be appreciated.
In short, i have tried the instructions given in the rockwell document (56rf-um001_-en-p.pdf)
but it did not work for me
Kindly give me a step by step procedure, if possible it would be great
I found the mpsetup.exe, tried to install but it doesnt let me select the option of install or remove, i cant click it, its un-selectable
any thoughts?
Did you ever get anywhere with your project? I've been able to add the AOP and communicate properly with the reader/block. Have not gotten a working code for reading/writing to and from yet, and the manual either has typos or I have a corrupted version.
hi frnds, i m working with RFID tech., but i don't know how should i use and configure RFID module on Control Net N/w used by control...
3,571
We have a product we are now building and are planning on using RFID tags to ID trays of product as they move through the process (5 individual...
1,462
Hi. I was wondering if any of you guys have a problem with the RFID reader/write BIS M-4A7-082-401-07-S4 from Balluff. The problem we are...
665
Good afternoon! For the past several days, I have been trying to set up this Balluff BIS018A RFID head to communicate with a Do-more BRX DM1E-M-D...
5,572
Good Afternoon, I am currently designing an HMI application that needs a screen that shows about 20 of the latest RFID [stored in PLC] and have a...
2,725
