RHC & TDF on 1747-L553 5/05 CPU-64K OS500
kay_gsr13
Oct 2011
NC
57
Hello,
I have a system that use to have a 1747-L542C 5/04 CPU -32K Mem. OS401 Series C FRN 3-8 and was upgraded to a 1747-L553 5/05 CPU - 64K Mem. OS500.
Since the upgrade, the system has been running for over 5 year without issues but recently, management has requested some changes. I uploaded the program and modified the codes. Upon verifying the project for downloading, all of the RHC and TDF instructions used in the program are flagged as the following errors:
ERROR:RHC instruction is not valid on the currently selected processor!-> 1747-L553 5/05 CPU - 64K Mem. OS500.
ERROR:TDF instruction is not valid on the currently selected processor!-> 1747-L553 5/05 CPU - 64K Mem. OS500.
Referring to the instruction set, these instruction can be used on SLC 5/03 OS302, SLC 5/04 OS401, and SLC 5/05 OS501 Series C processors. I have not had a chance to physically check and confirm the label on the processor, but logging on remotely and looking at the Controller Properties and I/O Config, the previous programmer was able to work around this limitation somehow.
Does anyone have experience with this issue or seen a work around? Any suggestions? Thanks.
K
Contacted Rockwell, they are stumped.
Tried creating a blank project with a 1747-L553 5/05 CPU - 64K Mem. OS500 processor and the the RHC and TDF are greyed out.
If I set the controller to a 1747-L553 5/05 CPU - 64K Mem. OS501 then the error clears, but now the processor is a mis-matched.
Anyone?
I'm rewriting a program for CLX that was originally SLC. It makes use of RHC and TDF instructions to create TimeStamps for a velocity calculation...
1,325
Hi all, Please, could someone give me a working example of how to use the RHC instruction? I want to measure the speed of a machine that works...
1,436
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
98
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
560
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
410
