RiceLake Indicator -> CompactLogix
BMK
Feb 2019
Yakima, WA
wondering if anyone has experience getting weight data from a network port on a RiceLake indicator into a CompactLogix controller. I have explored setting up a generic ethernet module but am stuck on the connection parameters.
I have the scale indicator set to continuous output through the network port and I can see the value coming through PuTTY.
If anyone has suggestions or questions feel free to ask. Thank you in advance
dmroeder thanks for the reply.
*Forgot to mention I'm using a RiceLake 880 indicator
I don't have any of the option boards, but I can configure the network port's to be static or DHCP. I have the IP set static and I know the port number as well.
I've seen the Ethernet I/P card for this indicator Part Number 179159 - https://www.ricelake.com/en-us/prod...thernet-ip-880-1280?partId=22095#/information
In the manual for the network adapter card they give specific details on how to set the generic ethernet module Input, Output and Configuration instances/sizes. I'm guessing the fact that they include the option to have a network adapter module is not only to make it easier to be able to communicate from an AB controller, rather to make it actually possible to communicate. I guess I'm wondering if anybody has been able to get communications without the use of the adapter cards. I have a suspicion it is not possible.
I don't think it's default Ethernet port is capable of speaking to your CompactLogix. Keep in mind that TCP/IP is not the same thing as Ethernet I/P. You would need to get the optional Ethernet I/P module for the device to talk to a CompactLogix.
I work for a company in Yakima, I went to Perry Tech for instrumentation. Graduated in 2016. Noticed you're from Vancouver. Not too far away.. Are you familiar with the area?
I lived in Yakima for 2 years, I also graduated from Perry in 2002.
Majors > Minors :)
Very cool! Perry was one of, if not the best educational decision I've made.
I've lived here my entire life :p
Woah there, those are fighting words! Minor's milkshakes are pretty tough to beat.. haha
Sorry to derail the all-important milkshake quality debate, but just in case you wanted my two cents worth on the original question ;)
...the newer (5370 and later) Compact Logix processors can talk TCP/IP, but it's very labour intensive and unwieldy. I would think of it as an method of last resort, if you have no other options.
Here, you do have other options - the Ethernet/IP module. In almost 100% of cases, the development time you save in using such a module will outweigh the cost of it several times over - and when you're done, you have a simple, lightweight, industry-standard solution in place.
I use Mettler Toledo weight transmitters all the time - they too have Ethernet (TCP/IP) adaptors and Ethernet/IP adaptors. The Ethernet/IP adaptor is more than three times the cost of the Ethernet (TCP/IP) adaptor, and it's 100% worth spending that money. I've not used Rice Lake specifically (they're not so big under here), but if your Ethernet/IP interface card is a whole $40, I wouldn't even entertain the idea of doing anything else but ordering one of those, and a spare.
LOL, I get derailed easily.
It looked like that Ethernet I/P adapter on their website was $575.
Oh, well, maybe don't worry about the spare then ;)
But for my money, even if it was double that price, I'd be going that way.
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
I'm looking for flush mount max 22mm, 24VDC,RGB indicator light with UL/ETL listing.
834
Hello all, I'm coding on a CP2E-N with CX-programmer and trying to get my head around some of the clunkier parts of it, since I'm more familiar...
2,838
Hi Guys, I configured some FactoryTalk SE multistate indicators but they only reflect state changes only after screen closure and reopening...
1,101
Hello Everyone, I am trying to connect a A&D EK-6100i Weigher to my Micro 800 PLC and read the current weight. For now I have managed to connect...
4,190
