RIO Fault #0204
r8er_h8er
Nov 2005
Tulsa
I have a new system I'm configuring and have an issue with talking to the Remote I/O. The system is a Ring, I have an EN2TR in each of the Redundant Processor Chassis, the redundancy link is operating correctly. I have three ETAP's in the system (only one is currently connected in the "Lab") and one EN2TR in the Remote Chassis. The EN2TR in the Remote Chassis is the Supervisor. I can ping all IP's with no problem, I just cannot get the Remote Chassis to communicate. I get RIO Fault #0204. I have attempted to research the Knowledge Base and have had no luck.
Any directional pointers anyone can get to me?
Error 16#0204 is an ordinary timeout.
What exact modules are giving you that error ?
Are the -EN2T modules in the redundant chassis configured for the same IP addresses and loaded with the proper firmware for your Redundancy Release ?
I've encountered a situation where the SLC 5 connected to a Compact Logic via DHRIO does not send the Compact Logix a fault notification if the...
2,975
Hey all, I have a 1747-SN RIO Scanner which I don't intend to use anytime soon, but I want to leave in the rack. However, if I leave it in the...
3,022
Hi all, We are using the ControlLogix as configured below to collect data from a DH+ network for use in 2 x CompactLogix L35E on EtherNet. Is...
6,106
Hi guys, I've recently started doing an upgrade from a PLC5 system to a CLX system. The system currently communicates over DH+ between all the...
2,729
Hello, I have a problem where one of the racks (177 RIO adapter), would loose the communication to the control logix plc. what are the most...
2,661
