ROCKWELL hardware configuration
VictorBit
Sep 2012
Sweden
103
Hello all,
I need some help with my Rockwell configuration.
The program im working in is Rslogix5000.
The questions I got is that if this configuration I have done will work and what do I need to do for make it to work?.
-In our machine we used to have a 1769-L32E PLC but the customer wanted a 1768-L43 PLC instead an aswell an 1768-ENBT/A module.
((-The 1768-ENBT/A module got the wrong rack place right now beacuse I don't know where it will be in the real setup yet.))
I have posted a picture here with my old and my new configuration.
Im not so hype on Rockwell, used to work with Siemens and Mitsubishi.
((The things I have done so far is just enterd the PLC settings on 1769-L32E and press change module to 1768-L43.))
Best regards
Victor
I can't see anything wrong with it - but once you download it will tell you if there is a mismatch or conflicts - So Drive on!!
Hi victor
The only item I would check is your power supply. On your old system the power supply may have been In the middle of your I/o cards. I not sure as the power supply does not appear in logix tree, this is not a mistake it's just the way it's done. Now on the l43 range of plcs the power supply cannot be mounted in the middle of the I/o cards so I would jut check out the power supply rating in the manual just to be safe, but as frosty said your config looks fine
Donnchadh
Trying to get hold of three 5069-AENTR modules in the UK and it’s a problem, next delivery to Rockwell UK distributor is September! Is there a...
19
2,870
Hi all, Where can I find the latest hardware series information on Rockwell's Literature library? Specifically a 1756-85E. I want to know the...
1,978
I was defragging, and looking around under the hood of my company laptop. When I went to Contol Panel\Add Remove Programs, if I SORT by SIZE then...
7,257
Customer is adding an extension rack to an existing A22. They wired and powered it up, I configured the new cards in the PLC starting from slot 23...
28
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
74
