Rockwell- IO Forcing management
dalporto
Jun 2021
Montreal, QC
258
Hi.
This is the first time I do a project with Rockwell PLC from scratch.
I started a bit just building some AOI for a couple things I need to be sure it was working against InTouch.
Now I'm looking into being able to force whatever I need to force during commissioning.
I mostly used M340 and M580 over the last 10 years and nowadays we can force whatever we please with a M580 so this isn't even is an issue anymore when we cannot get the actual status from the field to test a logic.
Rockwell is still quite different. I don't want to double-up every tag I have just in case I need it during commissioning. I'm not quite sure yet what I can force but it look mostly like only the physical IOs; if I have a tag in between that is being written somewhere I cannot do anything with it.
What are you best practices about that?
Thanks.
Personally I don't ever force IO.
For an input I branch around it and put XIC Toggle_To_Test_Input[200] and just toggle that bit to test.
To 'force' an output ON another branch around the whole rung with its test bit. To Force an output OFF I XIO another test bit right before the output.
To make sure nothing is left ON I create a conditionally called subroutine that unlatches each one I put in and then unlatches the bit I toggled to run that subroutine. When I'm done I toggle that to clear all forces.
Also, if something happens in the future and an IO needs forced until something is repaired I can toggle that bit (as long as it's not a safety issue)
Yeah, that's what I did today on a live setup but I only had 2 to test.
It looks that I'd need a lot of these to build an "acceptable" simulator. But for wired IO I'm already covered with my remap blocks (I start the simulator and every 16 IO have an INT / WORD that I can modify). I'm looking more for some of the "software" bits in between.
What do you use for AI? In Schneider I use a selector block in a FBD section with a tag starting with SIM_ on each (I usually don't have many AI). I'm not sure how to proceed with Logix yet.
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
170
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
127
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
