Rockwell Library Designer Auto Increment
slnd54
Oct 2018
kansas
I am using the Library Designer tool to create PLC code. One of the standard routines that our company uses for simulation has individual XICs that set the .Inp_Sim of each PlantPAx object. We use an array of DINTs and reference the bits so that we may turn on/off individual objects for simulation.
It looks like this:
XIC Sim[0].0 OTE PT1000.Inp_Sim
XIC Sim[0].1 OTE PT2000.Inp_Sim
XIC Sim[0].2 OTE PT3000.Inp_Sim
Within the Library Designer, I have experimented with adding a subObject and having it autoincrement parameters, but I cannot seem to reference the variables where I need to. I would like to avoid creating an additional BOOL outside of the initial array for each analog device.
So my question is, does anyone have experience with iterating through a DINT array (SIM[X].Y) for each object within Rockwell Library Designer?
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
Hi All, I'm planning to use Rockwell Library, and I am testing the P_AIn block and P_Alarm block for the alarming functionality. I think the...
2,255
Hi guys, I have been looking around for SISTEMA libraries, and i have not been able to find a library with Rockwell components. Can anyone help...
3,008
Hi there, The Pilz PAScal tool (V1.9.0) will not allow me to import the Rockwell SISTEMA library (V2). It appears PAScal will only import older...
3,627
Would anyone be willing to convert the Process Library Example files to CompactLogix and post it here - I don't have support for ControlLogix...
2,455
