Rockwell Software Confusion
pr_wainwright
Jun 2011
Stockton on Tees
109
The company I work for has just purchased RSLogix 5000 professional edition & Factory Talk View Machine Edition. The packages contain loads of other software DVD's that I don't know if I have purchased or if they are trials or what. The Rockwell website doesn't give any clues either.
With RSLogix 5000 I also get a DVD with FactoryTalk View Site Edition although no serial key is listed in the activation envelope?
With FactoryTalk View Machine Edition I also get a DVD with KEPServer Enterprise & FactoryTalk ViewPoint for FactoryTalk View 6.10 although no serial keys are listed in the activation envelope?
I don't want to install loads of trial stuff that I can't use in future. Has anyone got a clue about the above mentioned software packages?
Any help appreciated.
Paul.
FTView SE you aren't licensed for, It is a seperate set from Machine edition. SE is the scada software for computer install, I presume you got ME to do the panelview+.
KepServer is used if you want the Panelview+ to talk to a non-rockwell PLC, You don't need to install it if you aren't.
Viewpoint isn't something i've played w/ much, but I think you need a seperate license for that as well.. Don't quote me on this one ;)
KepServer can also be used to read various other devices, not just PLC's. KepServer is an OPC and its supports hundreds of protocols - Modbus, SNMP, etc.
Viewpoint does requires an individual license.
-Josh
Setup only require software
You have given extra CDs as accessories without activation key. Thats are only run in trial version. You have to setup only those software whose activation key is given. Only that software are run fullfeldge;)
Dear All, I am confused in a situation and I am sharing the problem statement in detail,i hope it will be fruitful as in past: I have a Allen...
4,491
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
154
Hi all, I would like to replicate my PC onto a virtual machine so I could use it on a different laptop when I'm on site. I have never created a...
290
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
253
https://www.reddit.com/r/PLC/comments/187sy3w/rockwell_is_straight_out_dropping_some_heat_today/ :site:
469
