Rockwell
RSView 32 7.20 When I open the app. I receive error "failed to launch vba server". I can open other application with no problem. Running on XP Pro.
Straight from the Rockwell Knowledgebase
Cause:
The VBA Project has a reference to an Object Library that is not installed on the computer. This is most likely to occur when sharing projects between computers.
Solution:
Open the RSView32 project on the computer that originated the project and record all referenced Object Libraries in the VBA IDE. Make sure these Object Libraries are all properly installed on the destination computer.
OG
Runtime Error!
Program:C:\Programs Files\Rockwell Software\Rsview\SPTED32.exe
This application has requested the runtime to terminate it in an unusual way.
You really need to post better questions..............
Is this a NEW message? Is this occuring AFTER the VBA message?
PLEASE help us help you.
OG
OK..........
Did you read the post above from the Rockwell Knowledgebase? It sounds like the projects you are trying to open were copied from another computer, but not all files got copied. That would explain why a new app does not get these errors.
Go to the machine(s) where the originals are located. Use the Transport Utility to copy all files and folders.
OG
This is computer developed on. But your right I removed the the .vba file it opened with no problem. I will try and replave the .vba file. In my dreams!!!!
Background for the question: A service man from a sub-supplier has made changes onsite to a Siemens PLC and HMI program. He has not made a backup...
288
Hello all, I am an Industrial Electrician, and deal with a little bit of everything including PLC troubleshooting and programming. When I started...
169
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
175
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
178
Customer is adding an extension rack to an existing A22. They wired and powered it up, I configured the new cards in the PLC starting from slot 23...
158
