RS emulator and remote racks
hanseriksson
Apr 2015
wa
24
Hi
im new to the emulator and im woundering how you test a program with a remote rack .have not been able to find any info in the manual about this so im hoping somebody here knows
the program i like to test has a compact logix controller 4 vfd drives 1 remote rack flex logix
Hans
The Emulator doesn't allow you to create any modules other than the simulator IO module. You can't create Ethernet modules or motion modules or any real-world I/O modules.
You could create a user-defined data type that was similar or the same as the IO modules you are using, and use that for emulation, but you can't actually connect to the drives or I/O to test their functionality.
when i switched the controller to the emulator contr the I O moduels disaperd did replase the one in the local rack with the emulator IO moduels when it comes to the remote rack can i replace them with the emulator IO mod if so what rack slots do i need to use
at the moment im not to impressed with the emulator its not that user friendly but it is the firts time im using it
Hans
RSEmulate 5000 doesn't delete the I/O configuration with ControlLogix processors. But it DOES delete the I/O configuration with CompactLogix processors. A big PITA. I wish Rockwell would address this too.
And I wish Rockwell would look at writing a proper emulator, and not just deliver a cut-down version of SoftLogix.
I know for a fact that softlogix/emulator do some things entirely differently to an actual hardware setup, which means you have to be uber-careful you don't "test" something that won't actually work in the controller proper.
I guess they figure that most people will test their software on the actual controller hardware they will ultimately be using, and use an I/O simulator like PICs. That's always going to be the preferred route when a proper emulator isn't available.
Hi all, I am having RsEmulator ver16 and FT view SE ver6. I want do develope communication between them remotely i.e. On laptop I will run Logix...
6,020
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
93
HI all, I have a backup from a Series 7000 Cognex camera. I am trying to restore and see the vision tools used in the job. Can I restore those...
76
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
302
