rs linx
roxusa
Nov 2008
NJ
994
I have a EMBA machine that is running on a PLC 5/30
The front end computer is also from Allen Bradly running windows 3.11
The hard drive crashed (old machine) and my IT had it recovered, cloned and put on a new hard drive. The front end computer comes up with what it should but does not see the PLC, The OEM (EMBA) thinks I might have lost the RSLinx
licence. Does any one know how to load it. Would it load using a E-MOVE like a laptop. There is an A drive on the front end computer.
THANKS
What program is running on this computer that may or may not use RSLinx?
I don't remember AB making PC but I could be wrong on that.
Yes, they probably corrupted the RSLinx license when they cloned the hard drive. It might even have been WinLinx if it's really Windows 3.11.
EVMOVE was the classic utility for moving these licenses to and from 3.5 inch floppy disks.
Do you have the original floppy diskette ?
I don't know if RA will create new license floppies anymore at all. It can't hurt to ask.
It is the set up computer and it is running windows 3.11 It lets them store orders to re set up the machine like CNC. The tower on the PC has Allen Bradley part numbers (I have pictures) I do have floppy's with RSI Master Key's. Not sure if this is what it takes since it is Windows 3.11
I do not have the Original floppy disk. I have some of them but most are corrupt from sitting in a control cabinet for years.
Unfortunately the front end computer makes all the manual set ups as well so I am down.
There's a phrase for your situation and it involves canoe propulsion.
If I were in your shoes I would be talking to my local RA office about trading the emergency use of an old master floppy for a purchase order for an upgrade project.
Edit: You mentioned you have some old master key floppies.
Without arguing the fact that you shouldn't have those if you're not an RA technician or salesman, you could try to use EVMOVE to move the activations off those floppies onto the new hard drive. Or just see if the software will run with the floppy in the A: drive.
My first step would be to run EVMOVE or EVMOVECF to see if they will tell you about any activations that might be present on the new hard drive.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
193
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
106
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
104
