RS Logix 5, where to locate serial number
LMDAVE
Oct 2006
New Orleans, LA
50
I have a laptop with RSLogix 5 on it, the activation remains on a keydisk. I want to know what serial number it was installed to so I can match it to the keydisk, but I cant get into RSLogix 5 and look at the help icon that displays the serial number.
Is there any file on the hard drive that would have the serial number info in it?
Dave
Well, the floppy disk I have is bad, but I'm trying to make sure this is the serial number it was installed to on the hard drive. If I run evmove from the harddrive it says "No activations installed" and closes.
The activation is on the bad floppy disk, not the hard drive. Technically, I just need to get a new master disk and reinstall RS Logix 5 with the new serial number.
The reason why I wanted to know what serial number RS Logix was installed to was to prove that this bad Master Disk was matched with this laptop.
Usually I go into RS Logix 5, select help, and select about, and the serial number is shown there. So, I figure it;s buried on the hard drive somewhere....or maybe not since the activation is not on the harddrive.
Hi, The MicroLogix 1200 has a Com 0 port and a "HMI/programming port". When looking at the PLC, there is a port on the left side and a port on...
1,746
AB Logix 5000 Controllers Compact Logix L24ER PLCs Can not use Produced / Consumed (due to network / bandwidth limitations) so this is not an...
3,386
I'd bet more than pocket change that once-upon-a-time I saw an official spreadsheet type chart that listed all of the features for the various...
2,236
Hi all, I'm installing RSLogix 5000 on a new laptop, and I want to have versions 16 to 20 installed. On my old laptop I have version 20.00.00, but...
1,850
I want to buy CompactLogix 1769-L27ERM-QBFC1B for my machine. In the manual, it says there are 4 embedded analog inputs. My boss wants me to do...
1,343
