RS logix 500 enetering text question
ktm
Oct 2007
NC
I do have a RS logix 500 specific question.
I am practicing typing in using the text bar.
here is an example I am using.
XIC I:1/0 XIO I:1/1 OTE O:2/0
what I have a question is how do I add information to that above line to identify my inputs and outputs? an example would be the
XIC START the XIO STOP and OTE MOTOR 1
someone mentioned using a symbol to designate possible ->
but when I tried to type it in
XIC I:1/0->START XIO I:1/1->STOP OTE O:2/0->MOTOR1
The program will accept the line and show up as such but without the identifier above the symbol. I can still right click and edit description and add it in manually but I was wondering if there is a way to add the description to the text line.
any help or tips are appreciated
Go ahead and make a short program, possibly just one rung, with identifiers. Now double click the rung and look at the line. Does it show the identifiers. No. The line is showing just the logic. I believe that's the only way you can enter it.
If you want to use symbols for addresses. try populating the symbol fields first.
Open the data tables to which you want to assign symbols. Highlight a bits or word you want to symbolize. Then click in the symbol field below the data window and type your symbol.
When entering symbols, the spacebar will automatically be changed to underscsore, and all letters will be capitalized for you, so this method of entry is pretty quick. Also, RSLogix checks for, and forbids duplicate symbols.
The description field is there too. Once a symbol is defined, it will be substitured automatically in the ladder editor. I am not 100% sure about entering rung mnemonics, but you can fill in the address fields of instructions by typing the symbol instead of the address.
You'll have to test this when you type a rung mnemonic, RSLogix should translate the symblols into addresses when you hit enter.
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
445
269
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
108
121
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
200
