RS Logix 5000 UDT
cjd1965
Apr 2007
UK
1,659
Hi I am doing a project for 1st time in years and i am very rusty
I am trying to create a udt for process valves
The UDT has content but the size is showing as 0 bytes?
This is where i need help
I have attached a screen shot showing the issue in yellow highlight
Thanks in advance
Mine registers a size once I hit the apply button.
As a suggestion, unless you are following some external data arrangement, is to declare all the BOOLs first then work on up in data size for the elements.
Is 'TIME' an actual type (possibly a previously defined UDT?)
When I attempted to add an element of a type which hasn't been defined the the 'size' went back to question marks (as would be expected). I see that you discovered the problem. You must use types that exist. If you intend to create a type called TIME then do that first. Elapsed time in a standard timer is in milliseconds and is held in a DINT. Try that.
Hi Bernie
In Siemens it is a datatype so i need to flush some of that. I will change it to DINT for the timer preset values
Cheers
Hello, Wondering if the following setup would work. 1. Local PLC on the network has an array of 25 REALs 2. Supervisory PLC on the network needs...
1,826
Hi there, I am doing work for a customer who has a UDT that uses parameters like this: PLC_REG_TO_SEND.GROUP_15.1234_DINT[1].0 I believe these...
1,820
Hello, I'm writing an interface program to a machine and because the bit data is packed into 16 bit variables, it's nicer to create an UDT to...
4,931
Ok, I am having a tough time with an application and figuring out how the best way would be for me. So here is what I would like to accomplish: I...
28
9,280
Good Evening , I still have many "Mental Blocks" when it comes down to programming. Could you tell me the difference between a UDT and a AOI ...
26
16,853
