rs logix 5000 ver 20.0
RY_Guthrie
Nov 2011
Las vegas, NV
263
I have ver. 20.0 of rs-loigx 5000 installed on my laptop, my question is this, I have a running program installed in a compact logix running 19.11 ver. I know I can flash the firmware, but that requires shutting down the plc, can I down load the older version of software for free? or does it require paying for it also?
Chances are that the other versions are on the same install media that you used to install v20.
As OZEE stated, if you installed the software using the DVD disc, then pop the disc back in and you can add v19 or any other version to your current installation.
If you downloaded the software for v20, then you can go to the RA Software Updates page and download any version. Provided you have a Tech Connect contract in effect.
OG
Hi Thanks for your time everyone. I am integrating the The endress FML621 over ethernet/ip to RSLogix5000. Any other endress instruments has a...
1,463
Im running windows 7 on vm and studio 5000 is version 27. I opened a clients file this morning to add expansion i/o and drives and as i was adding...
1,428
I am new to programming, and I was asked if I could take the 0-10V signal from a load cell and scale it so we could see it on or HMI...
2,335
Hi all, Status update for posterity, and also request for help! I have spent the day installing as much RA software as possible on Windows...
16,019
I'm working on a retrofit job, it is using a Control Logix L55, Ver 13, with Devicenet IO and Ultra 3K drives on Devicenet. Now I need to add in...
8,460
