RS Logix 5000 with signal converter 232 balluff
jero
Apr 2020
Corodoba
hola buenas tardes
Tengo que comunicar un lector de codigo de barras con un compact logix a traves de un convertidor de señal 232 balluf que va aconectado a un puerto de un maestro i/o link balluff .
adjunto foto del plano.
primeramente segui un manual que voy a adjuntar tambien.
cree el diagrama de bloque predeterminado de balluff que explica en el manual. pero hasta ahi llegue.
alguien hizo esta programacion alguna vez??
muchas gracias! saludos
  • IO-Link Device AOI User Guide.pdf
Jero:
Hola, My first recommendation is to read your IO-Link device manual completely, and try to find out if that device is compatible with your bar code reader.
Then you can go on.
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
151
Dear all, I have 1794 IE8H Hart flex input module to which one Emerson HART flowmeter is connected...I have gone manual of flex module...I have...
20
8,838
Hello everyone i have an issue related with analog signal, i have 1769-IF4/B card i add the module in the plc software but the values dint change...
2,157
PLC Guroos, I need to configure an flow switch ESD signals, but all relevant instruments are in another PLC system, both PLC's are connected with...
1,250
Looking for help regarding my below question, I'm not very experienced in the world of PLC, but trying my best. Here at job site we have two PLC...
1,528
