The Plc Kid Member Join Date Feb 2009 Location Macon, Georgia Posts 3,233 Oct 19, 2009 #1 If i have address b3:0/0 on rungs 2-12 but i want to change rungs 3-8 to b3:0/1 in the same location as b3:0/0 is there a faster way then manually changing the addresses is there a seach and replace by rung?
(8{)} ( .) Lifetime Supporting Member Join Date Apr 2004 Location Israel Posts 625 Oct 19, 2009 #2 1st replace rungs 3-8 then replace rungs 2-12. Depending on complexity you can export or copy the rung to notepad. Good Luck (8{)} .) (Yosi)
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Oct 19, 2009 #3 The search and replace can be used but you'll have to manually choose when to "Replace" and when to "Find Next". Or, you can start after the addresses you want left alone and turn off the Wrap checkbox.
