RS LOGIX5000 FBD, How to use old tag
Nyains
Dec 2017
New Delhi
Hi everyone,
I am using Rslogix 5000 FBD programming, I programmed using BAND, TOT BOR instruction etc, and every time i insert instruction it create new tag for eg BAND_01, BAND_02, BAND_03 etc.
Now i have deleted BAND_02 instruction from program and when i insert new, it create a new tag BAND_04.
Now i want to use tag BAND_02 instead of BAND_04, How can i use it in online controller ? Pl help
Adding a function block to a sheet can do two things, create an instance of the instruction, and create a tag instance for that instruction. This would be annoying in ladder logic, like if we placed a TON instruction and it automatically creates TON_1 as the timer tag.
The name above some function blocks is the name of the tag it was automatically assigned.
The problem is there are tags already created and may default to the "Program Scope." In the Studio 5000 designer, go to the program where the function block routine resides at, then click on "Parameters and Local Tags," you should see a tag that matches your instruction naming. Delete or rename tags, then click on your function block instruction and rename to the desired tag. If it is not there, try looking in the "Controller Scope," "Parameters and Local Tags."
Deleting tags is possible while online, the tag has to be unused in all logic.
Hi, RSLogix5000 v20.01 FBD editor is making me crazy when it scrolls up or down automatically each time I move a block or a tag or even delete a...
1,284
I am curious as to how many of you actually utilize the SFC and FBD available in RSLogix5000. I find both very useful depending on the task at...
2,322
Good day all. I would like to know if it is possible to change programming languages in RSLogix5000? For example, if a program is written using...
4,859
Does anyone know if there is a way to have Logix automatically create the required program tags for an FBD routine when you copy it from one task...
1,528
Hi, I have a project using RSLogix Function Block Diagram and a Prosoft Profibus module to communicate with a Siemens DCS My problem is it has...
14,035
