RS View ME 4.0 install
Mar 2011
Alberta
I am trying to install my RSView Studio ME 4.00 software on a different laptop. When I try to install it says I need FactoryTalk Automation platform 2.00 to install. When I try to install FactoryTalk Automation platform it says I have a newer version already. It's an endless loop and all I want to do is install the RSView Studio ME on my computer. Any suggestions?
Answer 1: Uninstall EVERYTHING else Rockwell first. FactoryTalk Services are not backward compatible. Then you can ONLY install FTView 4.0, and nothing else, or it will break again.
Answer 2: Use a virtual machine, and install FTView 4.0 in the VM. (Preferred method)
I very strongly agree: if you're supporting a FactoryTalk View SE 4.0 system, create a VM and run FTView Studio inside that.
Even if you are just running PanelView Plus terminals, it's still far safer and more successful to install the RSView/FTView 4.0 / 5.0 / 5.1 / 6.0 / 6.1 revisions in separate virtual machines or linked virtual machine snapshots.
I got a new laptop at work so im having to reinstall all my AB software.... I installed FTView machine edition, but after the install, the only...
2,022
I need to be able to open a customer's FT View project and make any changes if necessary. Which one do I need??? :hmmm: I don't want to have...
2,596
Greetings! Anybody has a clue how to uninstall FTView Studio V11 and after that install V10? I uninstalled everything I found in the...
7,527
I am doing an upgrade from a panelview 600 to a Panelview plus 7, but I am having an issue with the ascii files displaying correctly all I get is...
1,645
Hi all, I have not got any reference nor manual yet how to re-install FTView ME Station on VersaView CE 1000H terminal (Firmware Ver. 3.20) since...
1,242
