RS View Studio animation without controller
Rob S.
Sep 2008
Maryland
739
I am beginning a project and I want to begin working on the HMI project so I can use in meetings. I would like to show some animation of the machine i am planning on building. I am going to be using RS View Studio. I am not going to have a controller conected yet,but would like to have some animation. How can I write an expression to see animation such as a indicator on or off , or a image appear and disappear?
Thanks in advance.
if you loaded the SAMPLES that came with the software, look at the Automotive Plant for a good "moving motion" example ...
this uses a Derived Tag (Automotive Motion) to provide a number which ramps up from 0 to 100 ... the changing value is used to provide "visibility" and "position" links to move the little cars along the assembly line ...
TIP: the part that sets how fast (or how slow) the derived value gets updated is under a menu selection at the top of the Derived Tag setup screen ... that's not intuitive - but that's where it is ...
you can also position something like a Horizontal or Vertical Slider control on a screen - and manually move the slider to "write to" and change a value ... this value can then be used to move "tank level" bar graphs - and other similar animations ...
Check your system tags as well. There are "blinkfast" "blinkslow" tags that you can set to an indicator or animation. There is also a "seconds" tag that you can use for tank levels as well.
Should have also installed a program called Animate.exe which has all sorts of handy things for doing animation without a PLC.
Thanks JaxGTO , where would I find Animate.exe ? On the CD ? I am surprised I did not load that .
Thanks in advance
On my machine it in C:\Program Files\Rockwell Software\RSView\Animate.exe
I think you can also download it on the AB site if you have support.
It also works well with Wonderware and RSViewME for testing.
I am having trouble with the expression editor setting up some colour change animation. I have a bool tag and an int tag. I will have four...
1,623
I am trying to set up fill animation on a polygon. How do I determine what color it fills with? I want to have it start as one color and fill as...
3,382
I'm having an issue with getting animation to work as I expect it should work. It only seems to change when I exit the display, then come back to...
5,256
For no apparent I cannot select any object animation on my projects. When I highlight an object, select Animation (from the menu or via a...
7,600
Hello, I'm new to the forum here, as well as new to all of this FactoryTalk Allen-Bradley stuff. I'm normally a mechanical guy from the solidworks...
12,915
