RS View Studio ME Edition
BrandonM
Oct 2006
Prairie Du Chien
18
I have just uploaded a program file from a Panelview Plus 700. When it gets uploaded to the Folder the Extension is .MER. I was wondering if anyone knows how to convert this file to an .APA so that I can restore the application. I was on the Allen Bradley Knowledge base and wasn't having any luck. Any help would be greatly appreciated.
If you have FactoryTalk View Studio ME (formerly known as RSView Studio) version 5.0 AND the .mer file was created for the panelview firmware version 5, then you can import the .mer file into Studio, and re-create the project.
If the .mer file was created for an older firmware version, then you have to resort to the unofficial workaround described in the thread that Mark posted. Keep in mind that the old unofficial workaround does not restore 100% of the original project (I believe some things like alarm messages don't work)
Thanks for all the help, I did get it figured out but what a bad system, you shouldn't have to jump through that many hoops to get it done. But thanks again.
Hi all, i need help on how to use Recipe for FT SE. I read the manual, it mentioned about RecipePro+. However i cannot find in the software. How...
1,544
Hello, Im trying to learn how to use VBA with factorytalk view so i can later design displays using tags from PLCs and im having some trouble...
3,801
FTView is Not opening any of my projects . . giving me this message " Failed to open the FactoryTalk Private Directory for the application...
4,052
Hello, Does anyone know a Macro command in FactoryTalk View Studio to copy a Datalog database file to a USB drive or some other location? I...
3,694
Hello everyone, I have a line that is currently running an older version SE local station application. I took a backup of it and "updated" it by...
6,059
