rs485 temp controller to slc5/05
nathan.slade
Mar 2010
n.s.w
69
hi all
i would like to know how to get a temp value from a temp controller into a slc5/05. i would normally just use a analoge input with 4-20ma but without a working analoge input card im looking at other ways.
thanks
Most temperature controllers that have an RS-485 port implement Modbus RTU serial protocol. The newest SLC-5/05 controllers can run Modbus RTU Master on their serial ports (Series C FRN 11).
So all you need is an RS-232 to RS-485 converter, some knowledge of Modbus, and a communications manual for the temperature controller.
This might be really easy, but let's start with details about the temperature controller make and model and a link to a user manual that describes the RS-485 interface.
Hello Ken!
Pretty late but I am also trying to get temp values from a M2B+ temp controller here is the link to the manual : https://www.diecastmachinery.com/Us...8_Sterlco M2B+ Controller Complete Manual.pdf . I also have an SLC 5/05 with Series C FRN 13. What kind of RS-232 to RS-485 converter do I need? And I am using RSLogix500 (Version 5.2) and am unsure how to make this work with the software I currently have...
Many Thanks!
I am currently have a bit of an issue connecting to a Love 2600 temperature controller via RS485 full duplex with a Grid Connect NET485 Modbus RTU...
2,325
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
261
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
255
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
106
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
279
