RS5000 running slow any ideas
tadams73
Nov 2008
Tennessee
25
I have a system that seems to be running slow.The data on my panel views is lagging behind real time. The actual info is behind about 3 to 4 parts where it always was almost instant.We can stop running parts and the last part info showes up about 2 minutes later.Also I now have a communication card fault that clears itself ever 45 mins to.Last night i hooked up to it using rslinx via an ethernet hub and it took at least 10 minutes for linx to display all my device net nodes. Do I have a plc problem or do I have a comm problem.Thanks
Sounds more like a network problem. You said "Ethernet Hub", is it really a hub? not a switch? If it's a hub, throw it out now. What else is hooked up to this network? If it's anything more then just the PLC and the PanelView, try isolating them from the rest of the network.
Go into Internet Explorer and type the PLC's IP into the address bar.
You will see an interface and one of the options shows you the errors in ethernet traffic.
If you have a large amount of collisions/errors, you may have a speed problem with one of the devices.
Also check the RPI (Request Packet Interval) on all of the ethernet modules (in RSLogix). This shows how often they update their information over the ethernet connection.
Most things do fine with a 60 ms - 100 ms RPI. Unless it is something critical like remote I/O keep that very low, like 1 ms.
Hi I have a new machine that is written in studio version 21. The only version I have on my laptop is rs5000 20.Can I download and run studio on...
1,587
I am working on a v20 RSLogix 5000 project, and my computer started running slow, so I pulled open the task manager, and discovered there are 4...
9,730
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
378
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
113
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,221
