RS5000 Tag usage ?
antoine
Sep 2002
62
How is it possible to see at first sight if a tag in the list is used or not ?
For comparison: in RS Logix 5, you just click "Usage" and the used ones show with a "X", With Schneider PLCs they are displayed with bold characters.
Antoine
Along that same path, what if you are trying to see if you have an open Analog input without doing a search on each one?Thanks
George
George
Those you need to do a cross-reference search on, but you can do the 'base' cross reference, and search for say: "Local:9:I", which will show all references to an analog input in slot 9.
There is no quick way to see if tag elements (such as points on a digital card or individual elements within an array) are used or not. The only way to tell if they are used is to cross reference each individual element that you care to check.
I have already had conversations with technical support, and requested the addition of this function. Like you said, I think that a basic feature of RSLogix 5/500 would naturally be available in Logix 5000.
Maybe they'll add it in version 18, but I'm not holding my breath.
rdrast is correct about the base cross-reference.
I have a dummy tag which is a 32 item bool array.
I do a cross reference on dummy (not dummy[3]) and it will list everything in the dummy tag.
This works for udt (sees all components), slot (local & remote).
in version 16 used bits in a tag are greyed out, this is the closest thing to what you are looking for i think.
cheers
My fellow PLC tech just found something weird, as in there are only two of us who could have done it but we didn't. And we know we would not have...
2,296
Good Afternoon all, What started out as a "small" change has ballooned into something more than I bargained for. The program I am...
6,013
I am trying to use a tag that Alias's an Input in RS5000. The tag is under 'Controller tags'. Wonderware will not switch states when the tag...
4,428
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
378
