RSEmulate 500 idiot guide
exiled
Jun 2002
England
131
Hi folks,
I have been given access via our network to Emulate 500 V5.00.
Now i would like to try before i enegize 503&4s but i have no idea how to run the program properly.
I have created, verified an saved a program,
ive added the EMU500 to the driver list in rslinx, i can see this running, cant see my cpu though?
When i try to open the said processor it tells me i have nothing in the memory of cpu ect. "what am i doing wrong"
Or can somebody point me to a decent pdf ect.
thanks in advance
Ps i have just discovered thread about version 6 been free now. maybe ill have to get that, But were from chaps?
Just open up your RS Logix 500 file directly with RS Emulate 500, it will ask you to assign a station number. Once that is assigned you get just a blank which screen. At the top you should see the Run/Halt button, make sure it is running.
You should now see the CPU in linx.
You can then open up the project file with RS Logix 500 and go online with the emulated processor through linxs.
You cannot make online changes, you must go offline, make your change, verify the change, then save it.
Then you must stop the processor in emulate 500 and go to File -> reload, then put the processor back into run mode and go back online.
Emulate 5 works the same way.
Hi , i am working on a project which has 4 micrologix 1400 plcs which they are all connected via ethernet switch and the HMI is pvp+6 .is this...
3,184
I am trying to download RSEmulate500 today. The website seems to be partially down. I can get some places, but not there. Can someone point me in...
2,098
I have a new client that wants a modification to a PanelView Plus screen, I have the original .apa and .mer files and also the .rss files. I was...
12,081
I'm trying to test out my application that involves a PVP+ and a RSLogix 500 program. I can run the PLC program in RSEmulate 500 no problem, but...
11,678
Did anyone see this? I just downloaded revision 6.0 and this is in the Release Notes. I also noticed Vista support comes with RSLinx 2.55. OG
19,360
