RSL5K Program deletion
Dec 2010
Burlington, NC
402
Does anyone know if there is a "GOOD" reason why we are not allowed to deleted an unscheduled program online. I can delete it offline (don't know about program mode), so I know the prerequisites are met to delete them. That would make it a lot easier to perform cleanup on running programs (so I wouldn't have to do it on weekends).
going by memory here - but try deleting all of the components "below/within" the program first ... once all of the tags and routines have been deleted, then I "THINK" you'll be able to delete the Unscheduled program ...
I can't delete the "Main" routine because the program configuration will not allow me to select none as the "Main" routine. I can do it offline, but online the drop down box arrow is greyed out.
The "Main" routine is completely empty, has zero code in it.
well - so much for my "memory" ... I'll play around with it - and let you know if I come up with anything ... maybe "offline" is the only way to go ...
It may be "offline only. I was just wondering why Rockwell doesn't allow us to do it online.
You'll go prematurely grey wondering why some of Rockwell's idiosyncrasies are the way they are. It's a robust product, and most times behaves, but there are some definite deficiencies....You can't cut/paste multiple rungs online either....or search/replace online...or change an alias online. There's a long bucket list of things you have to do a complete download in order to change something minuscule.
I'm fairly new to the Controllogix scene and thanks to the wealth of info on this site I am learning rapidly IMO. One area however that I'm...
1,676
Hi One customer who has quite impressive CLX system, complained me that the battery went down. As OEM is in backrupt, he asked me to download...
2,613
Hey All. Weird Issue today. Never before have I had trouble with this particular PLC in the 3 years its been here. Regularly online with it. I...
1,385
hey all. probably an easy one for you. just downloaded 525 drive firmware v 5.01. As I am sure I have done before. Control flash gives me the...
2,451
I just bought Logix5k for the first time this past week, and downloaded a couple versions. I spoke to Rockwell support and they said that for me...
3,477
