RsLink Lite 2.41/2.42 Download
Peacemaker
Feb 2004
22
Recently I bought a 1747-PIC interface cable from plccables.com but I could not use it because of "Fatal Error initializing PIC Driver". My laptop is running Win XP Pro SP3 with RsLink Classic Lite V2.53 and my RS-232C serial port is real type not usb-serial converter one. Of course I launched RsLink in "Application" mode. I tried clean installed com1 after uninstalling com1 but still no luck. Driver is in "Stopped" state with "Startup" "Start", and "Stop" tabs are all grayed out. I visited their website and belatedly found out it seems to work on RsLink V2.41 or V2.42 only. Anyone knows where I can aquire that old versions?
Thanks in advance.
Strange...
Even though they are competitors of mine they are also friends and I have never (*repeat* never) heard anything bad about there products, I have purchased them (PIC's) and resold them, have you brought this up to them?? You may have just got a bad cable.... this does happen from time to time, I have tested a cable sent it to a customer, then it fail for what ever reason...
Also try this www.plctrainer.net/Setting_up_a_PIC.pdf
I am running an older version 2.5 on this laptop and have used my PIC on it, I am sure that Chris's PIC also works on this one also running XP
From your post I think you know what you are doing but read the procedure as you may have skipped something??
Mark
Hi Mark, thank you for your feedback and I followed your procedurs but same thing. I checked device manager on my laptop and found out
"AB PIC/AIC+ Port" has not been loaded onto COM 1. Something wrong with XP Pro Service Pack 3 or laptop's configuration? No clue yet. Thanks anyway.
Thanks in advance.
I have the same exact problem. Let me know if you found out how to fix it!!!
Thanks,
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
444
Respected Members; Good day. I want to perform the following task: 1. successfully fetches the data via RSLINK / DDE to excel. 2. Now i want to...
17
4,442
Hello Friends; Good day. I have RSLINK 2.52 i have also 1784-U2DHP. But in the RSLINK configuring driver there is no 1784 U2DHP shown in the...
2,136
Hello friends; I found a code for VBA use in excel to read the Tags values from RSlogix 5000 through RSlink. The code is here: Dim OPCServer1 As...
3,887
Hi all, Kindly find the attached snapshop.I got this error while try to connect RSLogix 500 to wonderware intouch.
1,145
