RSLINK stop / offline
gfranco
May 2008
RIZAL
Gentlemen.
Good day I have problem in our DH+ com. When I using The DH+ communication (PCMK) and Go Online on RSLogix 500 the RSlink Classic com. automatic Go offline.It is posible that we have a problem in one of our processor,cable or virus on processor.I already try different notebook just to make sure that the problem is not in our downloading terminal (laptop). and if I directly communicate in processor using RS232 its work well.
Thanks,
Is you node number the same as another on the same network??
This is my setup, it may help...
Yes its almost the same setting, daisy chain connection the communication loss to processor for about 2 to 3 minutes eventhough the RSLink was working and all nodes were found.
Respected Members; Good day. I want to perform the following task: 1. successfully fetches the data via RSLINK / DDE to excel. 2. Now i want to...
17
4,422
Hello Friends; Good day. I have RSLINK 2.52 i have also 1784-U2DHP. But in the RSLINK configuring driver there is no 1784 U2DHP shown in the...
2,127
Hello friends; I found a code for VBA use in excel to read the Tags values from RSlogix 5000 through RSlink. The code is here: Dim OPCServer1 As...
3,849
Hi all, Kindly find the attached snapshop.I got this error while try to connect RSLogix 500 to wonderware intouch.
1,141
Dear All: open the rslink classic launch control panel ,you need " stop"and then cancel the "always run as service "and then "start". if it can...
1,290
