rslinx and communicating to enbt static or standalone
remullis
Oct 2012
Georgia
179
I have network connections through to most processors in our facility. I am wanting to setup a control logix rack for testing and I am trying to get it online.
I have a new enbt module and used bootp to create a ip address. bootp pushed the ip to the enbt with no problem, but I cant get it to go online through linx.
I am thinking I need to assign a gateway, but I cant connect to do this. Also, when I look at what is already established in linx, in configuration it has IP's assigned by node #. In RSwho, in the tree it will show this IP and another IP in brackets. This is where I think I am missing the boat. How would I be able to communicate with this processor standalone through a cat 5 cable and avoid the main network?
Thanks in Advance.
Can you ping the IP address assigned to the ENBT module from the PC running RS-Linx? If not, then check the network setup to make sure it can connect to that subnet. If so, then troubleshooting within RS-Linx.
I cant ping the IP, but that's what I don't see is how to setup the subnet. Rslogix,bootp nor linx gives me that option. If it does, I'm not seeing where.
thanks
rem
The Ping utility is typically available from the windows command prompt (type "command" without quotes into windows search, then "ping" w/o quotes into the command prompt window.
However, the RS-Linx window implies your PC can see other devices in the 10.178.196 subnet. It would be worth expanding into one of those ENBT modules to make sure it is reachable.
Maybe there is a physical connection problem (cable, switch, port, etc.); though a successful bootp would seem to rule this out.
Hi, I am trying to read data values from CAT generator via monico(redlion) module to be displayed on factory talk view studio via RSlinx...
4,809
Hello, I am new to this group and to the plc. I am trying to connect the plc-5 to my computer using usb serial adapter. I am going to configure...
17
4,010
This is my first time using Factory Talk ME and I am trying to setup my communications. RSLinx enterprise will not recognize my processor in slot...
3,587
Dear all i mon site and i am facing problem that my RSLINX is not communicating with the RS232 port it is giving error actually this processor was...
18
6,471
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
67
