RSLinx Classic Activation Problem
SPAZ
Jan 2019
Wisconsin
Hello all.
Just ran into a problem recently, and I’m guessing it might be somewhat common. I bought a license on 1/4/19 for RSLInx Classic – Single Node, installed it on Windows 10 laptop, and it ran fine for exactly one week and then it automatically dropped back to the “Lite” version. During the week, it was fine during as I have been using the OPC server.
On closer inspection now, I’m guessing the activation I did after install never took (and no error was displayed,) so it was just running the 7 day grace period. Uninstalled and re-installed 4 times and just gave up. Made sure firewalls and virus scanner was down. The feedback from the installation process is horrible, and there is never any real indication as to what is going wrong. However, I did pick this off the top of an RA log text file just after one failed activation attempt right after re-installation (note divide by zero) –
System.Reflection.TargetInvocationException: An exception occurred during the operation, making the result invalid. Check InnerException for exception details. ---> System.DivideByZeroException: Attempted to divide by zero.
I tried to go through activation again in FactoryTalk Activation Manager, and the application just closes (crashes really) just after I hit "validate." No feedback on whether license is invalid or anything else. Went online to Rockwell activation site and to try the same thing, but it asks for “data file” after serial number and key, and I have no idea what that might be.
So, I have a ticket in for just activation tech support from RA, and sent an email to local distributor. Unfortunately, I have a field service call set up on Monday morning as it was fine all week so I'm hosed unless I can sort it out this weekend.
Anyone run into this before and figure out how to fix it? I have searched other threads here on activation, and this one seems a bit different. I only have RSLinx 4.10.00. Just downloaded latest version and tried that, same problem.
Thanks very much.
You might try installing the latest version of ActivationManager, or reinstalling it. Remove CodeMeter as well, it gets installed with AM. Once that goes, if RSLinx still isn’t working, try rehosting it and reactivating it.
Thanks ArtWalls. I did try that, as I removed everything and re-installed it all every time along with RSLinx. I even went so far as to remove any trace of all of the RA tools from the Windows registry so every new install would go in clean. Did not help. Same problem came back each time.
I found that using "uninstall" tools really does not clean up everything, and you have to go in and pick through the directories for a lot of leftovers.
Figured it out, after only 12 hours of screwing around….
FactoryTalk Activation Manager application doesn’t work at all for initial activation, crashes. Not sure why, but finally gave up. Activation method right after install also fails every time.
So, I used the RA website online activation method, which is more involved. Since this license is node locked, I got the 6- digit binding ID (serial hard drive#) from Windows “cmd” command, and entered that with serial number, key, and software version. It was critical to pick the software version that the license key came with, as the drive serial number entry field doesn’t show up if you pick a later install version (even if you already have that latest version installed.) Make sure to activate on version you bought, not the current version that’s loaded on PC. Activation seems linked to old version. After that, license file downloads to “Download” directory, and you have to find it and manually copy it to the actual license area of RA – which is bizarre. Wow.
So, it all works, but I am absolutely stunned at how much struggling I have had to do with just this one program activation. Horrible. None of this is intuitive at all. I can only assume that the node-locked activation process is struggling to get the hard disk serial number on my PC (even with no active firewall or virus scanner) - but there is no feedback on that, and things just crash and vanish.
My hope is that maybe this post will save someone 12 hours and some hair. ;)
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
193
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
161
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,591
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,138
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,422
