RSLinx Classic Stopped And Still Can Go Online With PLC?
Jan 2016
UK
85
Can someone explain me this? RSLinx Classic service is stopped and yet from RSLogix5000 I was able to go online to the PLC. (Screenshot attached)
When I did RSWho in RSLogix5000, finding the ETHIP driver, then finding the IP of the ENBT card, backplane, and then the processor; every level took few minutes to browse. I don't get as to how it could browse with the service stopped. I could not run the service as it was set for manual and I didn't have admin rights on the account I was logged in as.
If I would go Start->RSLinx Classic, nothing would happen and that wouldn't start service either.
RSlinx Classic can run either as a service, or as an application. Most of the time, it just runs as an application, meaning when you open RSLogix and go online, it starts up in the background and away you go.
Otherwise, you can run it as a windows service, meaning it's just chugging along behind the scenes all the time, and RSLogix uses it that way.
Generally, it's best to leave it running as an application, because when running as a service, you can't actually open the RSLinx Classic user interface (i.e. the application) to make configuration changes to your drivers and whatnot. But some things (e.g. SoftLogix) require it to run as a service.
You can switch between running as an application and running as a service using the RSLinx Classic Launch Control Panel from the windows Start menu.
I understand. But when I tried to run the RSLinx Classic application from Start menu, it didn't do anything and I didn't see any process running under the 'Processes' tab of task manager. Should it not be at least there if the application was running and RSWho required it to run?
In the bottom right on your screen look in the Windows System Tray (where the clock is located) for the RSLinx icon. Right-click on the icon and select Restore to open the GUI.
OG
When you click on RSLinx and it opens as a service it will not open a window.
Instead click on RSLinx Launch Control Panel, then make sure to uncheck the Run As Service box. Now you will have the application open.
If it was even running as a service, wouldn't I see it in the 'Processes' tab of Task Manager let alone the services that I provided the screenshot for?
OG
I know exactly what you mean, and I checked for the system tray besides the clock, expanded by clicking at the arrow and yet I did not see any RSLinx icon!
That is why I am so bummed about this and it doesn't make sense to me.
In task manager RSLinx shows as stopped, but if you sort services by name there will be RSLinxNG running (RSLinx Enterprise) right below it.
And if you click on Who Active Go Online or Go Online with the RSLinx application not already open, RSLogix will open the service RSLinxNG
So that means RSLogix uses either RSLinx Classic or RSLinx Enterprise? If classic is not available then enterprise is being used? I thought Enterprise was for Factorytalk View SE/ME only. If all this is true then that's a lesson learned for today then.
I don't think RSLogix is actually using RSLinx Enterprise, just that service.
For the screen shot I posted I opened RSLogix 500 on a laptop using EVRSI activation, not FactoryTalk, then clicked on WhoActive. And that laptop does not have RSLinx Enterprise installed on it.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
229
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
193
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,712
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,161
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,545
