RSlinx classic
Patrick420
Nov 2019
Mi
Why does my RSlinx classic keep saying not responding. I go to auto configure and it starts the process then when it gets to CRC or BCC it switches between them it just keeps loading then after a couple minutes it says not responding. I’m trying to connect to a micro 1000 using a 232 cable. Never have had this issue can someone help??
In general, and unfortunately, RSLinx Classic contains a lot of ancient legacy code, and it's a bit of a ungainly thing.
But let's address the DF1 Full Duplex driver, which generally works pretty well.
First, be sure that you have designated the correct COM port; look in the Windows Device Manager to be sure your port is numbered the way you expect.
If it's a USB/RS232 converter, post what exact unit you have. Some work better (especially with Autoconfigure) than others.
The MicroLogix 1000 could be set for Data Highway 485 as well as for DF1 Full or Half Duplex.
When you unplug from its serial port, does the Comms LED go off, or does it flash green ? If it's set for DH485 it will flash about 1/sec when unplugged.
If the MicroLogix came from an application where it was hooked up to a radio or other modem in a multi-drop system, then it might be set up for DF1 Half Duplex Slave, which can be very tricky to connect to even when you have records about the settings.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
219
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
169
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,621
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,148
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,451
