RSLinx classic
Terry B
Sep 2011
Willisburg Ky
We have several machines that are wireless. How do i I setup Linx to look for a wireless connection. I've it to connect point to point but not wireless.
Thanks Terry
Wired or wireless doesn't really make a difference to RSLinx. Connect your PC to your wireless network access point using Windows built-in tools. When you connect, you should be automatically assigned an IP address just as you would if you used a wired connection.
When you configure your EtherNet/IP driver in RSLinx you will see an option to select which network adapter to be used. Select the wireless adapter.
OG
When you configure an EtherNet/IP driver in RSLinx, it will give you the option to choose which adapter you want that driver associated with. You would see all available Ethernet adapters. Just pick the wireless adapter. RSLinx doesn't necessarily know or care whether it is wired or wireless.
OG
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
217
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
164
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,607
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,144
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,438
