RSLinx Enterprise - SLC5/05 Series C
Athlonus
Mar 2005
Kansas CIty
Has anyone found the patch for RSLinx Enterprise in RSView Studio not recognising a SLC5/05 Series C Rev 5 processor? I have an email in to AB support - and waiting. THe advice here is usually better.
There was a problem with the 5/05's around that Series/Firmware Rev that would not let it be recognized by RSLinx Enterprise. They should respond to you with the recommended F/W upgrade. This upgrade will also allow the Etherrnet I/P driver to recognize the 5/05 in RSLinx Classic.
Anawer from AB Tech
Problem:
RSLinx Enterprise fails to recognize the SLC 5/05 Series C module and displays a yellow question mark. Any application using the SLC 5/05 Series C module will not be able to add the ethernet driver for this device because the driver doesn't exist in the RSLinx Enterprise Hardware Database. The problem is related to the HardwareDatabase.xml file not containing the updated driver information for newly released products.
Solution:
Replace the HardwareDatabase.xml for the desktop with the updated file attached to this technote.
Installation:
1) Unzip the attachment to a specific file location.
2) Stop RSLinx Enterprise and RSView Studio
Note:The RSLinx Enterprise service can be stopped from the system services found under administrator tools in the control panel.
3) The attached zip file will contain one file once unzipped (HardwareDatabase.xml).
Desktop Installation:
4) Copy the HardwareDatabase.xml file from the Desktop folder to the following location "C:\Program Files\Rockwell Software\RSLinx Enterprise". Click yes if asked to replace any existing files or place the original file in a new folder for safe keeping.
5) Reboot the computer so the changes can take affect the next time RSView ME is run.
<<HardwareDatabase.zip>>
A little background: I have a 1756-ENBT/A and 1756-DHRIO/D bridge to access the SLC5/04 from Ethernet. HMI is a PV1400e on DH+. I am upgrading...
8,702
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,428
Besides a $3,000 license to purchase a RsLinx Gateway License for every remote computer network that I work on. Is there another way to get to a...
2,697
Hi, I'm running FTView v9 on a VM machine. Host win 10 64 bit, virtual win 7 pro. I've come to configure communication on this project (1st...
2,168
Good day, Does anyone know if the device shortcuts can be backed up, if they are stored in a SQL-Database?
2,019
