RSLinx Incorrect Status
Aabeck
Feb 2013
Detroit
1,860
I just want to know if anyone else has seen something like this before?
Using RSLinx 3.73, RSLogix 9.05PRO and L1747-552 Ser A FRN1, OS501 Ser A FRN 5
This is the only CPU that does this on me - but whenever I connect to it, RSLinx always shows the SLC5/05 as Faulted - whether it is in Run, Remote Run or Remote Program. The PLC has never faulted to cause the line to go down, and I noticed this last year when I worked on it last time.
is this the latest version of RSlinx? i would download a later version (maybe on another machine) and see if issue is the same.
it may simply be a compatibility problem in reporting status, do you have another 5/05 with the same firmware? if so does it have the same status report. i assume the plc is running fine (no minor faults in processor properties), just showing an incorrect status
On my way back today I made sure to take another laptop - on this one the PLC status shows correctly in all states.
Both laptops have RSLinx 3.73 and use the same Ethernet driver setup.
RSLogix 500 (this one has V9 - NOT-Pro) on both connect fine, there are no minor faults in the CPU, and with both laptops connected the one I use most still shows the CPU faulted.
I checked all the 5/05 programs I have archived and this is the oldest one that I connect to - if there was one out there I was planning on going to that shop to hook up to it giving them a "free safety update."
OkiePC,
Just in time. I was about to leave here after lunch - now I will try that before I leave now.
Thanks.
OkiePC,
That was it - thanks again.
Odd of all the 5/05's I connect to, only that one showed that way. Plus I never had a ControlLogix show wrong either.
Deleting the harmony files in Linx in the OT world is fairly similar to rebooting the computer in the IT world. 50% of the time it works every time.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
198
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
235
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
164
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
91
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
162
