RSLinx networking
Jacko20
May 2020
Burnley
Hi Guys,
I want to setup RSLinx network communications, but I don't have any Allen bradley equipment at home!
Can anyone tell me whether I should be able to see other equipment on the network (even if it is an unrecognized device). I just want to prove I have the network communications set correctly.
Cheers
Hi Guys,
Cheers
Yes. You should be able to ping all of the equipment on your ethernet network, in the same subnet. Nothing on devicenet, controlnet, profibus, etc
If you have a managed switch, you should be able to configure for multiple subnets.
Hi Guys,
Cheers
Not so sure if there is a way to get the IP linked with the EDS profile in RSLinx unless there is an initial connection.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
63
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
220
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
251
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
179
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
97
