RSLinx Professional with Wonderware
Aug 2009
Hyderabad
34
I am working for project execution where I need to get Data from RSView 32 to Wonderware, both are installed in different PCs in same network.
I have RSLinx Professional in the PC where RSView 32 has been installed.
Can I configure RSLinx professional as a OPC server to get datas to Wonderware. Can anyone guide me in this regard.
Sebastian C
I don't know how is the setting in the Wonderware, but I can guide you to the step of setting up the RSLinx OPC server.
1. Goto DDE/OPC>Topic Configuration... Make a new Topic in the RSLinx
2. Make sure the new Topic you make point to your targeted PLC and click done.
3. Test your RSLinx OPC server using the OPC Test Client (It should be installed in the same directory with your RSLinx)
4. Create a new file using and select RSLinx OPC Server
5. Add new Group and then add new Item
6. Under the Add New OPC Item browse to the Topic name your just created earlier
7. Browse to the online tags and you should see all the tags name in your targeted PLC will shows up
8. Select one of the tag and you should see the value change according to the real value on your targeted PLC
I think the Wonderware setting should be similar to how we set up the OPC Test Client.
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
37
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
226
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
268
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
183
