RSLOGIX 500 and the counter instruction
david90
Apr 2010
ca
202
The counter instruction has an OV, a UN and a UA flag but they don't seem to do anything.
For example, the OV (over flow flag) doesn't turn on when the accumulator value is greater than the preset value. Is this a bug or I'm just not using the counter instruction the right way?
The DN flag is an exception. It turns on whenever the accum. value is equal or greater than the preset.
Thanks for the help.
OV indicates integer overflow - for Logix 500 that happens when the counter accumulator is +32767 and an up count CTU occurs. The integer accumulator overflows and the count goes to -32768.
UN indicates underflow. It happens when down counting CTD from -32768 and the integer accumulator rolls around from -32768 to +32767.
You might want to go the literature library at AB.com and download the instruction set reference manual for your particular processor. It will provide full details on all the bits.
I think the OV and UN bits of the counter get set when it "rolls over" from 32,767 to -32,768 (or rolls under, -32,768 to 32,767)
I've never used a counter in that way though.
As TConnolly stated, the OV and OL values indicated integer overflow so you will know when rollover occurs. This is farm more useful than having special instructions for accumulator values higher than preset since you can implement that behavior using a GRT counter.ACC counter.PRE instruction.
Thanks. I read the instruction help that comes with rslogix but I was confused about what overflow meant.
You also should be made aware that the counter will set the .DN bit if you manually make the .ACC greater than or equal to the .PRE - EVEN IF THE RUNG IS FALSE !! This could trigger other logic into operation at the wrong time.
Counters belong to a group of instructions that execute even though the rung is false. In this case, it serves to reset the internal memories .CU and .CD, so that the counter will count next time the rung goes true. But it also does the .PRE/.ACC comparison, and sets or resets the .DN bit accordingly.
Tonight I'm contemplating using a technique I saw the other day while troubleshooting an installation of a legacy machine for a customer of mine...
4,089
Here's the situation: operators print off labels for finished products, scan the barcode on the label, apply the label to the products and place...
5,214
hi guys, i would like to put an running hour counter in the program of a ml1200 plc to be viewed on a hmi, but i am not to sure what instruction...
36
18,578
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
89
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
180
