RSLogix 500 Application Dropping I/O
kjmc1234
Apr 2012
new york
I am trying to load some code into a SLC5/05 rack. (I am brand new to working directly with PLCs, I get the concept and have seen them but I have never created a project and loaded it, that type of stuff) With that discalimer...
my problem is that when I loaded the code and switched back to RUN I lost I/O and got alarms. Only a handful, some Thermocouple Inputs that happen to be on one card and looks like some discrete that I did not look into which card had them.
I went to the I/O Config, card, configre -> adv configure and the values are all default values. There are two of the cards, I looked at the other(which was not alarming) and the config looks legit.
When this happened I went to a known working systme and uploaded code from that, went to the same card in the config and it showed up as not configured? Granted I didn't go to the "Read Config" to read the plcs config but still, its a working system I think I "should" be pulling all the info...rungs, i/o config...all except the comments without having to specifically use the "read I/O" command.
SO when I browse the project file I was given then browse an uploaded and fully finctioning one they both show the I/O for that particular card as unconfigured. THe other discrete I/O is probaly on the same card as well.
If it matters, the good config card is slot 7 and the default(but should be configured) card is slot 8.
Has anyone had this happen? I uninstalled RSLogix and installed a later version...8.3 CPR9.
Any Thoughts?
Sorry for the typos, its late.
If you zip your .RSS file and post it here, also list what module is in each slot by part number, including the power supply part number.
Some one will be able to help you.
It will happen about 5 out of 10 times. Someone probably needed some more inputs and added a card in slot 8. The old program you loaded had only 7 configured, so naturally the PLC did not try to read Slot 8 because you did not tell it to. It only does what you tell it. If you want to be sure, do the "Read Config" step, then do a program save to capture the actual I/O instead of what it used to be once upon a time.
Question No. 1: I am using RSLogix 500 which at its 'Tool' menu has 'Visual Basic'-'Run Macro',Visual Basic Editor' and 'properties widows'...
22,867
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
119
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
203
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
98
Will someone please convert this logic to pdf?
146
