RSLogix 500 Download Error
osamamalhy
Jan 2006
alex
89
Greetings
i have a PLC station SLC 5/03
i do upload the application program from it and able to go online with the CPU .
when i do any modification to the code that i do upload even i try to change any variables values and try to download it to the processor ,i have the below massage
{Download failed , Program is incompatible with processor}
kindly notes that the program i try to re download is the one that is exist in the CPU and Running
kindly advice
This is an old issue that I've seen quite a few times before...
7728 - RSLogix 500 - Program is incompatible with processor
Access Level: TechConnect
Basically, the program running in the processor can become a little corrupted. To knock it back into shape the first thing to try is a simple power cycle of the controller and then attempt a Download.
If that doesn't work, then try temporarily changing the "Processor Type" under "Controller Properties" to a different processor. Perform a "Verify Project" for the entire project and it will shuffle the Data Table file around. Then change the "Processor Type" back to the original and perform another "Verify Project". This will reshuffle the Data Table files back into shape as they should be. Then attempt a Download again and hopefully it should work.
Regards,
George
Note: Title should say 5000, not 500. Hello: I only have my 2016 Rockwell Toolkit software drive with me and I need an older version of RSLogix...
5,265
Download Free Version of RSLogix 500 Starter Software from Allen Bradley! Get Software RSLogix 500 Starter Software for 10-point MicroLogix 1000...
194,412
L
I just saw this on www.controls.net. A-B Rockwell is going to give away fully licensed copies RSLogix 500 Pro during the month of April. They...
33,637
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
181
