Rslogix 500 FFL to Unity Pro.
davexr
Aug 2008
Spanaway, Washington
33
So once again i am trying to create a program in unity pro from an Ab program. i have an FFL and FFU in rslogix 500 and need to use something like it in my Unity program. i have no idea as to where to start. the AB uses a source , a destination and a control register. i looked at the schneider website and this question was asked, schneiders answer was, no and that it would have to be created by the programmer. i guess my issue is that i can not figure out how to even start to program this. any help on this would be greatly appreciated. thanks
Thank you rankhornjp. i looked at that FB before but was confused as to how that might work like the FFL and FFU. if the FIFO itself (in unity) works the same as the control register (In AB) then i should be able to use this FB. Thanks again for your input.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
88
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
179
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
85
Will someone please convert this logic to pdf?
128
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
163
