RSLogix 500 little image blue bug with a red dot on its back
rbrower
Feb 2021
canton, SD
RSLogix 500, what is the little image next to the ladder in the project tree? it looks like a little blue bug with a red dot on its back. just curious, I haven't seen it before.
RSLogix 500  little image   ladder   project tree  blue bug with a red dot on its back  3-21 (1).jpg
No problem. Only remove it from debug if it shouldn't be in debug though. If you know who worked on the project last you should ask them if they're finished debugging the routine.
It is hard to tell without zooming it, but the red dot is actually a "D". So, a bug with a "D" gets us "Debug"
Debug ladder files will only download and execute in the RSEmulate 500 emulator program. You will see them offline, but they do not execute online with a physical CPU. I don't remember if they are displayed online with a physical CPU. I don't think they are, but I can't say for certain.
OG
From RSLogix help
Debug
If you want the data table file to be a debug file select this check box. Debug files are special files that you create to simulate your inputs. You can use these files with RSEmulate 500 to simulate the function of your ladder logic program on your personal computer. (Debug files are automatically filtered out when downloading to your real SLC or MicroLogix controller.)
I have a brand new copy of this software,never opened.What is it worth and whats it for?Keep in mind I am a musician not a computer guy.Any help...
1,920
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
170
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
83
Will someone please convert this logic to pdf?
127
