RSLogix 5000 Clock Design
I found a way to sync the clock on PC and my PLC. There is a tool you can download that syncs them and it worked great.
Just keep in mind very high execution time for LocalDateTime, looks like firmware does some complicated math calculating local time
This is from 1756-RM087
Clock design
Rockwell changed the WallClockTime for the newer version of Logix 5000. In order to get the local hours, you must use LocalDateTime in the Attribute Name in the GSV instruction. Otherwise element 3 of the result will be displayed in GMT.
I need a clock for a 1756-l72 ver 20. I can not use the wall clock because it is used for reporting. i need a clock that the time can be changed...
2,125
Hello I need to make a pulse every second of RSlogix the 5000th I have read this thread through and tested it as rdrast writes in Post # 14...
6,086
I would like to reset a counter at the end of the and say at Sunday at 6pm this there a system clock bit I can use for this? Do I use a equals...
3,347
101
202
