RSLogix 5000 Path
Brijm
May 2006
St. Marys, PA
645
I haven't used RSLogix 5000 a lot, but every time I do and attempt to go online, "who active" always checks the previous path first. This is very annoying, as I'm a contractor, and the last PLC I connected to, often has nothing to do with this PLC.
Just frustrating, waiting for RSwho to timeout, so it will let me navigate to the PLC address I'm actually working on.
Is there a solution to this?
Thanks - Brian
I never have to wait for the time-out unless I click on an unavailable node or address.
If I click on a driver I can scroll and click any other driver until I see the address I want to connect to. Then I click it and go on line.
Also there is a drop down box next you your WHO ACTIVE icon. If you have been to the address before you can open the drop down and click the path and go online.
I have a question on a subject of etherent nodes in rslogix 5000 project tree for a project that I am working on. I am trying to read if read...
4,706
Hello Everybody.. I am attempting to get online with our PLC via the Ethernet/IP card that is tied into our Wonderware 14 port managed switch...
37
17,324
i`m programming controlLogix with RSLogix 5000 and i want to set in my MSG Function tag that created in Program tags section , but in the...
6,957
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
84
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
191
