RSLogix 5k Structured Text Editor - Show line no.
MHammer
Sep 2017
Midjutland, Denmark
20
Hi
I'm working on a project in structured text in RSLogix 5k.
When I verify my program it shows the errors and warnings in the buttom of my screen.
Each with a line number. "ERROR: Line 76, ; exspected!" etc.
Is there a way to show the number of each line in the left side of the window?
So I don't have to count from the top, in some small cases.
//Hammer
No idea.
My quick solution is just to copy the routine, and drop it into an UltraEdit window.
There must be a way to enable it. I know that you can click on the warning/error and then see it right away, but it would be nice to see all line/row numbers.
Thanks for the answer.
//Hammer
Yes, it is working, but sadly not the solution I'm looking for. But Ctrl+G let's me search for the specific line.
//Hammer
Sadly RA doesn't offer solutions a lot of the time, you get workarounds. This is one example. They just recently offered regions in the structured text editor. Other editors have had this for years, so maybe line numbers will come next decade.
Phrog30, okay I'll have to live with that. As of now, my program is not that big that it would make a significant difference, but I just wanted to be a little prepared when the day comes :)
Thanks for all the answers :)
//Hammer
This looks interesting. Do you have any other details on it?
No, I did not see any other details but I hope something will be presented next week during the Automation Fair.
BTW - anybody is going to Houston? I am flying there tomorrow.
if you look at the bottom right of the screen it will show you the line number you are currently on.. not exactly what you wanted but that is what I use to check when scrolling through a huge file.
That or copy and paste it into notepad++
Hello, I please need your help why I cannot get the return parameter from the RET instruction to go into the return parameter in the JSR return...
2,820
Hello All, Please how can i edit a structured text program in rslogix 5000. Thanks
5,305
I don't use structured text too much, but wanted to loop some items, so i thought i should try it. Got a hang up. What i am trying to do is to...
4,731
I've created an add-on instruction in rslogix 5000 (in structured text) but I can't test it and I need to know if it is correct.. in a rung of...
6,097
Hi. could someone give me an example about TONR instruction in structured text? I need to build a sort of "clock" wich set a bit at each...
8,710
